I recently got a 1996 Q45t with ~320k miles, and, being a very old car with tons of miles, it has some problems, several of which I've taken care of already. The power steering currently will intermittently act up. Sometimes it feels like I have no power steering at all, others it feels like the power steering starts and stops as I turn the wheel. The problem rarely (ever?) presents itself on startup and seems to only start in earnest when the car is warmed up, but not every time the car is warmed up.
At first I thought that I should look at replacing the power steering pump, but when researching the problem, I found these:
tip-for-powersteering-problems-t413728.html
steering-shaft-to-rack-u-joint-question-t29640.html
These posts suggest the problem could lie with the u joint instead. Anyone have any ideas on how I can more accurately diagnose the problem before I go tearing the car open or spending money on parts?
The car has recently had a tie rod end, two steering rack bushings, a control arm, and a tension rod replaced up front, so I know that none of those parts are the source of the problem.
