Q451990 wrote:Actually the FPR (not to be confused with the damper) hooks to that clusterf..... of metal tubes that fits under the #7 leg of the plenum. Then a few inches later, that metal tube fits to another rubber hose that goes to the small vacuum port near the #7 leg of the plenum and BPT valve - just beside the larger black elbow coming in your picture.
That cluster of metal tubes can be seein in the '94 FSM on EM-6 just to the left of the throttle body in the parts explosion.
Heath
Awesome. Found it, hidden behind the other valve from the angle I was looking at.
And now for further proof that I should not work on any engine but KA's: I got the thing all put back together after putting it off for a long time, cranked her, and smelled gas. I am leaking, from what I can see, from the #7 injector, which is one I replaced. I am hoping the other one is not leaking, because I BELIEVE I can pull the #7 injector out without taking the plenum off again. I wish I had a way of testing this before I put it all back together...
Anyways, what's causing this? The injector is in there, should be in there, snug... does it just need pushed in harder or what? This is the most ridiculous engine, I just want it to run beautifully.
