Rex »
https://forums.nicoclub.com/rex-u6324.html
Tue Oct 16, 2007 11:25 am
To address several threads as of late .
I own/have owned 3 Q45's
My original, 1994, 75k - Stock + forged Z33 wheels/tires
Da Beast (rsiwicki), 1995t, 165k - Robert/NICO 8-Way ECU, 4.08 Rearend, 92 transmission, LevelTen with 2,400 Stall, Eibach with the Blues, Stillen Camber Adjustments, Stillen FTSB, Custom Ram-Air JWT PopCharger, Custom Headers, BRM Exhaust, Powerslot Rotors/Axxis MM Pads......
Quella (AZhitman), 1995t, 132k - 4.08 rear, Active sway bar, JWT ECU, low-mileage JDM takeout motor, all new belts, hoses, injectors and knock sensors, 18" 2004 Q45 Premium wheels with newer Michelin Pilot Sport tires, Eibach springs, new Tokico Blue shocks, polyurethane bushings, B&M transmission cooler, custom front strut tower brace, SS brake lines, NGK Platinum (one step colder) plugs, Hawk pads, SP rotors, SilverStars, etc (Note: Engine was swapped earlier this year [before I purchased] for a low-mileage JDM takeout. All rubber replaced and all injectors are new. New TPS and knock sensor as well.)
Da Beast is by far the more fun to drive, exciting and "seat of the pants" faster, even now that it doesn't have an higher stall or Level 10 transmission.
Anyone can say what they want, and yes, I only have a data point of 3 cars, but the headers/exhaust combo is the most noticeable modification, IMHO.
All those things said, if you don't have $7-$10k to spend after getting it to OEM standards, you're really just "bench racing". I didn't ahve that kind of money, but I bought the car from someone who did .
