I'm looking for O2 sensors and am considering three options:
1-Bite the bullet and pay $103 each for OEM2-Go cheap and get the NGK/NTK from
http://www.sparkplugs.com $49.85 each.3-In between and get Bosch from another online vendor $71.39 each.
Here's my question. For those of you who have purchased the NGK/NTK from
http://www.sparkplugs.com, did they look identical to the ones you removed?
Looking at the OEMs I removed they say "JECS LIC. BOSCH" which would make me think that Nissan sources the part from Bosch. Joe looked at a new one and agrees that it's probably Bosch. (Doesn't say JECS anymore...) Also, Bosch shows different sensors for 90,91,and 92/93. Infiniti has superceded all 90-93 the OEM part number that crosses to Bosch's 92/93 combination.
As if all of that isn't confusing enough, the right Bosch sensor seems difficult to find, and vendors are substituting NGK/NTK sensors for that side... when I asked Bosch about this, the rep. said that in many cases NGK/NTK sources the part for Bosch and the Bosch sensor may really be a re-boxed NTK.
I'm beginning to think that all parts are made in one factory and then re-labeled simply to confuse me.
I guess it boils down to this. If the NGK/NTK Sensors from
http://www.sparkplugs.com look and function like the OEM, they're probably the same and I'll buy them. If they look different, I'll go with OEM or Bosch. Any suggestions?
Heath
