Have someone watch to make sure the belts/fan are spinning when you turn it over.mayorofbuckhead wrote:It's making a sound like you're holding a drill when you turn the key! Please help!
You should instead rejoice you have such a competent repair facility available to you!mayorofbuckhead wrote:That's what I feared!
Yes, but text information has its limits when it comes to drill noises!mayorofbuckhead wrote:This is the age of information right?
Let me be a little more specific.fnomena wrote:Just had a problem with mine. My son was driving and it shut off. Took it to the shop and found out it was the module over the gas tank in the trunk. The module burnt out and the pigtale had shorted as well. When I get home I will look at the part number, but it's a computer module directly over the gas tank in the trunk. Part was $309.00.
