Q45 not fireing
henzeville1
Car: 1994 Q45
1994 Q45 was running great and it just quite now it just spines i don`t think it is getting fire any ideas.any help would be great.how do you check to see if it is getting fire?
THANKS ANTHONY
Q45tech
The best method is to read and the engine and EF/EC sections in the FSM.
A fast and simple way is to observe the current waveforms feeding coils and injectors.
The FSM shows where the different fuses are that feed injectors and coils along with ignition voltage relay.
Q451990
Welcome to NICO!
You might want to check for fuel. Fuel pump and fuel pump controller failures are common.
Also - you didn't happen to move the car while it was cold and turn it off without letting it warm up completely, did you? If so, it's very possible the engine is flooded. If that's the case try starting it with the accelerator pedal floored. Don't pump it, just floor it and hold the key until it either starts or your battery gives up the ghost.
Good luck!
Heath
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If you truly know the engine is not firing on one or both banks, then check the faulty bank's igniters.
