q45 needs more power
deener99
Car: 96 infiniti q45t
hey guys just bought a 96 q45t and wondering what i can do to get more power. read that cold air intakes are a waste of money. any suggestions
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Absolutely nothing for the 1996 OBD II VH45DE without the variable intake cam.
Restore it, maintain it, and enjoy it.
deener99
no turbo or anything
qship96
Car: 1996 Infiniti Q45
Turbo, even a good set of headers and exhaust will get you additional power- but still really not enough to be competitive with todays vehicles due to weight of car and the transmission- most modern v6 with 5-6-7 speed transmission will still beat you.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Turbos require a modified ECU if I recall correctly.
Headers are not worth the money for the power, unless you really want the power. And the OEM exhaust is only worth touching if the OEM one is rotted out.
And it really up to the driver of the car that determines who wins the race...
qship96
yup,enjoy it for what it is,a great long distance cruiser! Want a more speed and performance oriented car,buy a g35/37,and give up the ride,space,and isolation for more speed.
deener99
ok thanx guys and if i do decide to get a turbo and possibly a short ram air intake where would u suggest i look
deener99
ya i do wanna put some exhaust on it. anyone no what kind sounds good
Infinitiguy19
deener99 wrote:ok thanx guys and if i do decide to get a turbo and possibly a short ram air intake where would u suggest i look
Ram Air is a Pontiac design and sadly they went under...
Have you priced up a Turbo and the cost of a Engine Control Unit re-tune? Trust me I am not trying to discourage you but I know where your coming from... Use the Q for what it is...
qship96
Taking an old,higher mile vehicle and trying to add serious power to it is a recipe for early death- every mechanical component is already somewhat worn and tired......kind of asking a old retired race horse to step it up and compete in the Kentucky Derby again.......just doesnt work very well for very long!
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
You bought the wrong car buddy!
Seriously, 25% of your power is probably lost through worn rubber bushings, a tired transmission, and a filthy engine and intake.
Spend half of the 10k you would spend on a turbo/headers/exhaust (that would destroy your car within 20k) on simply restoring it, and BOOM you'll get probably 50+ horsepower.
These guys aren't trying to dissuade you - they're just being truthful.
deener99
ok thanks guys and it doesnt have high miles it only has 87xxx
qship96
deener99 wrote:ok thanks guys and it doesnt have high miles it only has 87xxx
Yes, but how many previous owners,and how diligent was each of them in their maintenance practices????? 87,000 miles can be just getting broken in to just near breaking down depending on how aggressive each previous owner was with spending on maintenance- and unfortunately history tends to show each successive owner of a used car {especially an expensive to maintain and repair model} is less willing or able to spend preventative dollars on the vehicle, until finally it becomes a 1000-3000 dollar car that is purchased by a younger person who wants to "soup it up"....they are generally the LAST person to ever own the car before it meets the junkyard.
Unnatural1
Car: 1994 Infiniti Q45
...yeah, mine too.
Take a look through the VH/VK Engine Forums for ideas on building power with the VH45DE. Lots of these engines have been swapped into other Nissans and have had more power extracted. The same tricks work in a Q45. The Q is no lightweight, but then again neither are a lot of new modern performance cars; the Charger SRT-8, Mustang GT/Shelby, etc....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
http://vh45det.com/
All pertains to OBD I VH45DE though.
StevieRaySTL
Car: 1990 Infiniti Q45 w/ Nico ECU
1993 Infiniti J30 w/ x-flow
1997 Toyota Landcruiser
--Have you checked to see if your injectors are working properly?
