Q45 must go to a good home in about a month, 1990, 57k miles
sensibleS13driver
gggyg
Modified by sensibleS13driver at 8:10 PM 6/8/2007
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Him and I have talked a lot about this car. I highly recommend it!
Q451990
Tell me about this new transmssion... are we talking factory rebuild? How about the injectors... new Infiniti installed at dealership or something else?
Sort of scary to see those things happen at such a low mileage. Especially since "Q2" was a low-mileage CA Q, and I have been working under the theory that picking up with excellent transmission maintenence and injector flushs should keep it going for a very long time...
Beautiful car though... has it ever had any body work done?
Heath
sensibleS13driver
Transmission is either a used or rebuilt unit from a local shop, not positive yet since the problem came up rather suddenly and we are still working out specifics. The injectors are from the dealership, as is all other maintenance thus far. No body work whatsoever, 2 or so negligible dings over 15 years isn't so bad. I'll be honest his car got mostly city miles (likely the source of transmission failure), but I will stand by its condition as being the best I have seen.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
now for the obvious question.............chain guides???? i'm sure the originals are still in there. looks real nice!!!!!!
sensibleS13driver
yes original chain guides :/ naturally i want the car for myself but that doesnt seem to be in the cards, i would remove the guides if it were mine.
Rex
Car: None
sensibleS13driver wrote:yes original chain guides :/ naturally i want the car for myself but that doesnt seem to be in the cards, i would remove the guides if it were mine.
That might work on the KA, but would spell trouble on the VH. Replacing them with the metal backed version is a must .
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Unless when he said remove he meant R/R
Rex
Car: None
elwesso wrote:Unless when he said remove he meant R/R
Common thing on the KA is to simply remove them.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Rex wrote:Common thing on the KA is to simply remove them.
Tell me you are not serious! Right?
Rex
Car: None
maxnix wrote:Tell me you are not serious! Right?
Seriously.
Quote »The KA24DE did have an inherent problem with the upper chain guide(between the cams). While it is not prone to failure, it is a cause of timing chain rattle. A Nissan TSB indicates the fix is to just remove it. It is not needed. In fact, my 98 240 did not have one from the factory.[/quote]
NISTECH wrote:I dont think there is a TSB on it. But there is a parts service file on it. when you go to replace the old one a note in their parts computer tells them to reffer to a book to see what other parts are needed to install the updated guide.
Mark86T
Car: 96 Q45, 86 Z31T, 01 Ford Ranger, 77 280z
I had a 90 240sx with that KA engine. Had a blown head gasket so I pulled the top end and had it totally redone. Saw that the timing chain guides were plastic & had broken to pieces. The chain then wore a grove in the aluminum timing chain cover badly enough that I purchased a new one along with the new/updated guides with metal backing. I could not imagine just removing the chain guides in the KA as the chain has too much slack. If you get into the engine that far, why not just replace them? MUCH easier job than the VH engine.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
The SF Bay area can be extremely hard onbrakes and transmissions. The steep hills do work things over real hard, depending on the particular driving routes. Try driving straight down 'wildcat hill' --from Berkely directly toward the Bay--straight, dropping very steeply--only a BMW,Prosche,or Brembo equipped car will make it without cooking the brakes.
sensibleS13driver
this car was in Orange County (Laguna Niguel) until 2001 when the owner moved to Walnut Creek. Most of the miles were before the move.
texasoil wrote:The SF Bay area can be extremely hard onbrakes and transmissions. The steep hills do work things over real hard, depending on the particular driving routes. Try driving straight down 'wildcat hill' --from Berkely directly toward the Bay--straight, dropping very steeply--only a BMW,Prosche,or Brembo equipped car will make it without cooking the brakes.
You're thinking of Marin Ave, and no you don't cook your brakes coming down that hill, uninformed exaggeration
gniknave
Mark86T wrote:I had a 90 240sx with that KA engine. Had a blown head gasket so I pulled the top end and had it totally redone. Saw that the timing chain guides were plastic & had broken to pieces. The chain then wore a grove in the aluminum timing chain cover badly enough that I purchased a new one along with the new/updated guides with metal backing. I could not imagine just removing the chain guides in the KA as the chain has too much slack. If you get into the engine that far, why not just replace them? MUCH easier job than the VH engine.
It's a little different with the dohc ka engine vs the sohc. On the dohc you can remove them, this is not the case on the sohc. I also replaced them on my sohc when I had it.
