SeattleQ45 »
https://forums.nicoclub.com/seattleq45-u14270.html
Fri Aug 06, 2004 10:21 pm
On my 94Q I occasionally notice less power at midrange rpms under heavy throttle. Everything was fine, until I ran out of gas one day (stupid mistake). After that I had rough idling,...the shop cleaned vaccum lines and adjusted the idle and everything seemed OK. Then some time later the car started stalling at idle. Took it into the shop and they found a bad injector (and cracked fan blade too). Replaced that and everthing was fine. Now I have the occasional lower power output when under heavy throttle. This engine really ran strong when I got it, so I'm starting to wonder if it is giving up. It only has a 107K on it.
Any ideas?
Thanks in advance!
