q45 mesh wheels on s13
bmadd2402
Car: Twin Turbo-shaft UH-60L, 1992 RB-240sx
will the q 45 15 in. mesh style wheels fit on a 5lug swapped s13? Ifounda set for 100 bucks at th junk yard. also, if so, what is the widest tire that will fit on them? I was thinking 235 50 r15s. I did try searching, and I know the info is out there, but help would be nice.
rsiwicki
Car: 95 Q45T
bolt pattern = 5x114.3 (5x4.5) Width = 6.5"
The mesh should be the BBS wheels. I have had them on my 95 Q from day 1 and they are the strongest lightweight things ever. I could not find any 15" tires in the size you mention....but the tirerack tire "spec" sheet will tell you the approriate rim width
Henry G
Pics of this wheel? I think there might be a q45 at a local yard I recently went to.
