Q45 MAFS Question
SlidingRPS13
Car: 89' 240SX Fastback
Got one for my Redtop... I already have the wiring diagrams. If I install this will it work with the stock ecu? or will i have to alter the fuel map in order for it to work correctly?
STR8E180
a Q45 air flow meter wont work on ur standard ECU unless u get it re-maped to suit the afm
and by the way ur beter of using a Z32 air flow meter its big enuff to make plenty of power and its also eazyer to tune with
