Q45 maf, will it work with my ka-t
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
Will the q45 maf work on my ka-t (de) I can get the maf and plug for farily cheap, just wondering if it will work, and up to whp, iam looking no more then 280whp (prob even less), of course with bigger injectors, and uping the boost. -Ricky
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
should.I have seen some people running them.
C-Kwik
IT can be made to work, but you will need someway of compensating for the difference in voltage given the amount of airlflow. THe Q45 MAF will read a lower voltage at the same airflow. You might check to see if the E-Manage might be prgrammed for that MAF. If it is, it would be as easy as wiring it up, and changing the setting on the E-Manage using a laptop. Not sure if the SAFC can do this but you can check into it as well. You can probably even tune it yourself using a piggy-back, but it will be a lot of work.
