q45 maf install on ka24de
6902brad
Car: 1991 240sx se
how or what info for diys
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Why would you use a q45 MAF on your KA24de that thing isn't that thing like 90mm? I don't even think something that big with a lower CFM 4 banger would even change the voltage on the hotwire. Why not an N60? If you were going turbo and was trying to make 550whp maybe I could understand a little better.
Modified by Bigvinnie at 6:44 PM 7/10/2007
KA-NEWB
Car: 1990 Nissan 240SX,1992 Nissan Sentra,1990 Honda CRX
yea
KA-NEWB
tyea
KA-NEWB
yea that would be something crazy
danielturbo23
Car: Nissan 240sx 1992
The N60 is the J30 and the maxima right ?
Bigvinnie
yep, N60 came on the j30 and 89-94 maxima's.
Neejay
Even using a N60 MAFS, you'd still need at least a safc, right?
Bigvinnie
Neejay wrote:Even using a N60 MAFS, you'd still need at least a safc, right?
yep, or an ecu tune wider diameter than the ka24de maf means that it will take longer to cool the hot wire. The hotwire also uses a larger voltage range than the ka24 mafs do....
driftfreek
Car: 92 s13
uhmm... these ppl that work on 240s everyday told me that theres no need to tune a ka24de if u install a q45 maf.
also, i heard that the q45 maf is better cuz its more sensitive and it be better when u tune ur ecu later on. i got an intake thats 2.75in diameter, and my maf sensor right now is like 2in. wouldnt be better if i get the q45 since its 3"? there would be better airflow right? im just sayin, correct me if im wrong...
Bigvinnie
driftfreek wrote:uhmm... these ppl that work on 240s everyday told me that theres no need to tune a ka24de if u install a q45 maf.
Let me correct your whole statement in a nutshell for accuracy.pay attention to the diameter of the stock s13 ka24de MAF, and then pay attention to the diameter size of the KA24de TB. The stock maf works as a restrictor plate, because it's diameter is smaller than the diameter of the stock TB.
STOCK S13 MAF 59mm
STOCK TB 66mm Inlet Diameter, to 60mm taper to butterfly
By changing out to the slightly larger diameter N60 maf you allow the hotwire to cool well while using the intake system as a velocity stack. A Q45 MAF is much to large to cool the hot wire and will only allow an NA KA24e/de to run rich because there isn't enough velocity per displacement to cool the hot wire fast enough. Really an N60 is all you need unless you up the compression enough to make lets say over 300HP NA donkeys.
