q45 maf ground?? chassis or pin 26?
meet07
Car: 89 180sx rb25det
Ok I coped a q45 maf as well as a q45 tb about 2 years ago. I used the tb and not the maf. Well I finally maxed out the stock maf and decided i might as well use it..
I notcied that the q45 maf has:-signal-grnd-power
then the rb25 has:-power-12v ground-signal-signal ground
what is the ground on the q45 maf?? is it a chassis ground or is it the ground that goes to pin 26?
thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Chassis is fine if not better because you want a really short and clean ground.
meet07
so pin 26 aka: signal ground is ok left alone then. I have a SAFC to change the hotwire settings.
