Q45 lost power
Oglokon12
Car: Infiniti q45 1994
Hi I have a q45 94 and I can't even make a Bourne out I press the gas and break and I won't even burnt it don't have traction control button and I bearly did a tune up and remplAce maf also the fuel pump is buzzing what could it be guys
qship96
Car: 1996 Infiniti Q45
something is wrong then. I can spin the {stock size} tires with 1/2 throttle from a dead stop, no power braking involved.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Fuel pump is buzzing... Gee, sounds like that may be the issue!
Q451990
:welcome: to NICO!
Yep... the fuel pump is a likely culprit. I'd replace it ASAP before it toasts the control unit.
Heath
Oglokon12
ok thankyou ill let you guys whathapend im gonna be changing it today also im gonna replace tps
Oglokon12
my q wont even burnt if i press full gas and breake at yhe same time lol
Oglokon12
what if i put my fuwl pump to run at high speed and see if it burn now bcuz i dnt want to change it if is gonna be worth less ????
BCC93QT
1995 Infiniti Q45
If its buzzing that means its going bad. Replace it. It is one of the cheaper repairs on this car. Get the O-ring and don't mess it up. Might as well replace the fuel and air filters if they haven't been changed recently.
Oglokon12
So I bought at fuel pump from a local younk yard and is working bud but it sounds like is misfiring the fuel pump when I push the white circles on top of. The fuel pump it work faster how can I fix tht
qship96
Come on,you have 5 posts in this thread so far,and each is harder to read than the last.Kinda difficult for others to offer help if you do not take the time and effort to communicate clearly.
