You don't need a dyno...........you have one on the car........the MAF voltage tells you every thing you need to know about air density and air flow.
A simple low cost [$40] manometer installed after the MAF will display the vacuum across the MAF and anything in front of it.......a zero to 10" W.C. should be fine on a Q or J or I/G20/35.
Less vacuum means more flow and more flow will raise the MAF voltage.
The norminal 1.0 volts at idle goes to a maximum of 5.0 volts in an exponental curve.........4.447 volts is the highest I've ever seen on a Q at 6500 rpm.
OBDII translates the voltage to grams per second and is read this way...........255 grams per second is around 325 HP and idle is 5-8 grams per second [8-10 HP consummed in idling [overcoming friction and accessory losses]]
"The complete intake system can be evaluated on the flowbench to indicate the level of power that the system will produce. The airflow at a test pressure of 25 inches of water multiplied by 0.272 will estimate the Horsepower that the components can make. (When a test pressure of 10 inches of water is used, the formula becomes the flowbench reading multiplied by 0.43). This number may shift slightly if the engine is not matched with the components or if the engine is extremely efficient. This estimated power versus air flow number has been a reliable indicator of predicted performance for well over a decade."
http://www.superflow.com/suppo...t.htm
http://www.nissaninfiniticlub....19671
This might scare you about the inaccuracies of using a K&N directly coupled to a MAF.........note the metal horn and shape of plastic deflector in stock air box.
http://www.ecutek.co.uk/tuning/induction/
