Some ideas for a single-turbo set-up:
1. Modify the passenger manifold and invert it.
2. Keep driver's side manifold as is, maybe remove the pre-cat, and direct the exhaust to the passenger side where it would merge.
3. Relocate the battery to trunk, relocate fuel filter and re-route fuel lines, re-route the AC line coming from the compressor to the firewall.
With the various stuff moved, there is about 3.5 inches of space between the engine and the strut tower. Would a 2.5 inch downpipe be sufficient?
With the battery relocated, there would be space for a turbo to sit. I would use some kind of flex-joint to compensate for the movement of the engine.
Now, I don't know what kind of turbo would fit in the battery space. I was thinking a T4 because I know that the Bentley Turbo R used it. Do you have any suggestions?
Again, these are all ideas. I am not in anyway a turbo expert, strictly a novice. I am however, a horsepower fiend.
So help me out, if you can.
