q45/j30 brake question
jeremy242
Car: 89 240sx
Are the rotors the same for the both of them or are they different. I have a set of j30 rotors and want to know if a set of q45 calipers will work with them. Thanks
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
The Brembo brake rotors for the two cars use the same part #s, so they seem to be identical.
TerminalVelocity
Car: 1996 240sx
Are the calipers any different?
ishkabibble
1997 Infiniti I30t
The calipers and pads have different part numbers between the two cars, so I would assume they are different.
jeremy242
Car: 89 240sx
the q45 caliper is bigger than the j30 but they are same thing. the only difference is the reservur in the q45 caliper is larger than the j30. I had ony found one source saying that the rotors were the same and wanted to double check it. Thnaks
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
You are correct. the Q45 calipers are slightly larger, but both the J30 and the Q45 use the same front rotors.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
What is the advantage to having a larger fluid reservoir in the caliper?
