mike93infiniti wrote:Well i have double checked circuit breakers and relays and i still have no power locks or power seats. What is up ??? There has to be a something that is causing both of these functions not to work. Is there a central distribution of these two functions? I am horrible with reading wiring diagrams.
Circuit breakers are not the best thing in the world but since we have them, we have to deal with them.
You mean three functions not to work. After my incident with a problem close to this I have the entire wiring diagram practically memorized in my head. Their are 5 systems (Power windows, sun roof, door locks, seats and Automatic Driver Postioner). Each go into two circuit breakers then on to a 25 AMP brown fuse in the engine bay fuse box. Then off to the fusible link holder (100 and 125 AMP fuse) then of course the battery. Excellent system Infiniti designed in my opinion but I have very limited experience and no degrees in this field.
So replace the circuit breaker for the power seats, door lock and Automatic Driver Positioner with a new one because you have nothing to loose but a small amount of money, OEM only.
I know how you feel about wiring diagrams because I used to find them challenging to read but now I love it. Like with everything it just takes time and determination and you will find the answer. Unless you introduce money then you can have someone else find the problem for you.
Also make sure the drivers side seat and power window switches are plugged in along with the center console window switches. Also if you feel up to it make sure the door lock timer under the center console is plugged in. Along with the Automatic Driver Postioner Control unit located above the drivers side foot well light. And make sure the power seats are plugged in but you will have to remove them to check.
