Q45tech wrote:Measure things to be sure as you never know what problems you create by relying on your senses.
That's exactly why I plan to measure acceleration with and without the piece. Seat of the pants measurements aren't very accurate. If I had a dollar for every modification that felt like it made my car faster and didn't, I'd have a lot of $.
Quote »I know everyone wants [prays] that the factory is hiding HP and doesn't want you to have it but not true.........if anything they are running out of tricks to get more from same sized engines.[/quote]I agree with you that there's not nearly as much power leftover as the aftermarket industry would like you to believe, but that's not universally true. Power is not always the primary concern for car makers. As an example, there is are a couple of restrictions in the intake on first generation Talons/Eclipses that can be easily removed, and result in significant gains on a dyno. The downside is that intake noise is increased slightly, which apparently was a higher priority than extra power. Taking the lid off the airbox on a mkiv Supra results in about 7 rwhp on the dyno, and intake temperatures are not increased if the car is moving. A freer flowing exhaust frees up large amounts of power on either car at the cost of more noise. If the Q45 intake is already optimized for maximum power though that's great. I just have a hard time believing forcing the car to inhale through an opening that small isn't restrictive.
When you're measuring vacuum are you measuring it before or after the MAS?
Quote »CFM is not accurate as the CFM can go up while the density goes down what you want to know is the weight of air per second of flow.......grams per second![/quote]That's true, but not relevant here since you're still drawing in outside air of about the same temperature in either case. If you remove that final piece, you're drawing air in from right behind the bumper, which is right above the opening for the radiator and is an excellent source for cool air.
Quote »500 CFM is smoking something as that would be 413 HP!!!!!!274/2= 137 x 4,000 rpm=548000/1728= 317 CFM x VE [93%]= ~~295 CFM
at 6700 rpm= 531 x VE [72%]=382 CFM maybe on a perfect day.At 7300 rpm the engine might just exceed 400 CFM[/quote]Like I said, I didn't have the formula at hand, but even 400 cfm sounds like a lot of air to pull through that opening. I've seen 200 hp cars with bigger intake openings than what my Q45 has, and they didn't have the many bends and twists along the way. I wonder why they didn't just run the intake straight down into the fenderwell rather than the convoluted setup they ended up with? I'd guess it might have been a noise issue, although a little more intake noise would be a good thing as far as I'm concerned. The Aurora that I had the misfortune of owning had the airbox in the same location and had a nice big opening (probably ~ 4 x 6") on the bottom of the box that lead to the fenderwell. It had a nice intake growl to boot.
