Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Dec 21, 2011 10:41 pm
I'm still not clear if you're asking how to get the instrument cluster out of the dash, or if you're asking how to disassemble the cluster...
If it's getting the cluster out of the dash, here's my breakdown from memory... hopefully it's complete.
Pry up the trim around the shifter (that contains the power window switches) from the rear using a thin screwdriver or narrow putty knife. Pull it rearward and disconnect the switches.
Remove the screws you exposed... two near the center console tray, two under the ash tray.
Remove the ash tray, and then remove the two screws you expose under the top of the ash tray.
The trim that surrounds the radio, climate controls, etc. should come off after unplugging the defroster switch.
Remove the cladding around the steering column. It's held on by 4 (or is it 6?) phillips head screws.
**Remove the cladding above the gas and brake pedals - the one that holds the floor vent, light for the floor, etc. There are a ton of screws and bolts there... keep up with which ones go where. You'll be amazed and somewhat disgusted at the same time by how over-engineered this portion of the car was built.
**Remove the two large bolts that hold the steering column up to dash framework.
Remove the trim panel that holds the cruise control switch, mirror switch, etc. It just prys off.
You'll see several phillips head screws holding the trim panel in place that surrounds the instrument cluster. Remove them, and then you can pop it out exposing the instrument cluster and it's four screws.
** you can skip these steps, leaving the steering column in place, but you'll gouge the bezel that fits around the cluster on a tab that sticks up on the ignition switch.
I hope this helps - good luck!
Heath
