q45 injectors on a ka24de question.
Roger_cha
Car: 91 nissan 240sx
as the title says, if i put the q45 injectors on my ka does it make my ka run rich or is it a perfect upgrade for it... my ka is stock with bolt on and stock ecu or do i need to get it tuned if i put the q45 injectors on.
onosqv
Car: '92 240sx Vert
I have no clue what cc & impendance q45 injectors run @, but w/ stock ecu, there is ZERO reason to change your injectors for performance upgrade.
As long as you are n/a & your stock injectors are working normally, you should never need to upgrade them.
airman86
x2, changing your injectors would do nothing unless you were boosting and or tuning.
ka-t4u
plus q45 injectors won't fit on a ka, they are way different i tried asking this question befor and thats what i got fo an answer
Roger_cha
well i heard that q45 injector would fit on a ka its just like the sr injectors. plus i just saying would i get a good amount of power if i upgrade them. but my plan is that try it on stock ecu and no boost to see if it makes a different if it dont then ill be boosting it.
onosqv
Car: '92 240sx Vert
Roger_cha wrote:well i heard that q45 injector would fit on a ka its just like the sr injectors. plus i just saying would i get a good amount of power if i upgrade them. but my plan is that try it on stock ecu and no boost to see if it makes a different if it dont then ill be boosting it.
100% w/o the proper tuning, your car will run like complete crap w/ any "upgraded injectors".
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
don't do it. period. you're ecu is not tuned for anything other than stock sized 270cc injectors.
