DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Mar 09, 2003 11:46 am
...? Not sure what you mean. It is very easy to take a reading from the injectors, assuming you have access (plenum off). You just need to remove the harness connector from each injector and take a reading across the 2 injector terminals. Biggest risk is with losing the metal wire clip that secures the connector to the injector, so be careful with it. Drop it into the engine and it'll fall into that black hole that I'm convinced is housing all of our lost-and-never-found parts.
