q45 injector problems
Negrodamus
Car: FX35
Car was running great untill the injectors started messing up where can i get the replacement injectors from? For a good price? The quote I got was for all 8 over 1G anyone can suggest better? I could get them rebuilt but just looking at other options folks holler.
Tommy K
"Yes they deserve to die and I hope they burn in hell".... Samual L. Jackson
http://www.everythinginfiniti.com for the best price on new OEM parts. I think injectors from there are $140 each?
Dont go with aftermarket injectors, as some have proven troublesome. Have you checked to see which injector(s) are bad? A few can be easily replaced without too much labor.
Love the screen name
Negrodamus
Car: FX35
thanks, I like the name as well a black man needs to create a buzz.....j/k anyways I will check on them I would just replace all 8 and go from there.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hmmmm..... have you performed any diagnostics, or are you just guessing?
Negrodamus
Car: FX35
yes did diagnosis on them 5 of the injectors are bad the ohms are off on the resistence on each injector, the injectors should read between 11and 14 ohms to be in calibration, however 3 of them were infinite or open readings, meaning they were not working, two others were at 26 and 28 ohms, my guess going out, if not so now. In reality all 8 should be replaced as I was told that once 5 are out the others will go soon
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Negrodamus wrote:yes did diagnosis on them 5 of the injectors are bad the ohms are off on the resistence on each injector, the injectors should read between 11and 14 ohms to be in calibration, however 3 of them were infinite or open readings, meaning they were not working, two others were at 26 and 28 ohms, my guess going out, if not so now. In reality all 8 should be replaced as I was told that once 5 are out the others will go soon
pretty much..... you could try your luck with used but i wouldnt.....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Oh...CA gasoline. Better research BG44K. You will be using it frequently.
redmanfx
Car: 92 Q45a
Wow, those are not good readings. You didn't have the Q stereo on did you? Many have gotten false readings because of it. Just a question. If you get all 8 injectrs Joe T. may help with a bit of a break on top of the normal NICO break.
red
DAEDALUS
Car: 1990 Infiniti Q45
redmanfx wrote:You didn't have the Q stereo on did you? Many have gotten false readings because of it.
That's impossible if done correctly. Been posted at least a few times in the past several years.
Negrodamus
Car: FX35
Yea looks like i have no choice but to replace the injectors, I may just buy another q45 for kicks while I fix this one
911/Q45
1996 Porsche Turbo
Just emailed you.
