franknitty69 »
https://forums.nicoclub.com/franknitty69-u25140.html
Mon Nov 09, 2009 2:19 pm
So my #8 injector went out and i replaced it with a blueish/purpleish one from scottsdale. the original was like a whitish/greyish color.
anyways since replacing it the q is hard to start but only the 2nd time. so if i wake up in the morning, q45 starts right up. if i drive it somewhere, turn the engine off for a few minutes and then try to start the engine, it takes about 2-3 key turns to start (as if the engine is flooded). starts right up after 2-3 key turns though.
could there be something wrong with the new blue injector? maybe too much fuel during ignition? if i disconnect the injector the car idles rough, but this sympton goes away. if removed the injector and checked the o-rings and everything looks kosher.
any ideas?
