Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Sun Oct 28, 2007 6:02 pm
Put the sand bags in the rear seat, not in the trunk, otherwise you'll throw the tail out. You want the weight over the rear wheels, not the overhang.
Except for black and purple, the Q's paint is incredibly durable. Wash it when you can and just plow through the snow. The salt will harm rubber bushings and mounts before eating through anything else.
Yes, the Q45 is RWD and front-heavy, but its better in the snow than almost any other RWD car from that era. Be sure your winter tires, whether they're all-season or winters, are OEM SIZE. Wider tires will leave you stranded. In 2005 I had to drive home backwards (simulated FWD) because I had wider tires.
