It'll definitely cost you over 1000.
Here's what you can do using the cheapest/most factory gear for the conversion.
Z32 starter, dunno how much, but my guess is $250-$300
Flywheel, well you can use one of two flywheels, the first being a factory 300ZXTT flywheel. I priced one of these up last year, the only one in the whole country that I could find was on this national parts database, and it was $700 used.
The other flywheel option is to buy my custom designed lightweight alloy/wear plate insert flywheel for $1k, specifically made for the VH41/VH45 engine. I made my own because I figured if it's going to cost $700 to buy a ****ty used factory item, I may as well build my own for a couple of hundred bucks more, and hey, mine's under 5kg and is going to perform awesome. It's designed to suit a 9.1/2" diameter heavy duty clutch/pressure plate combo.
Someone to adapt the bellhousing... the guy who did mine may be keen, though if you have access to equipment, it's pretty damn easy to do yourself. All you do is measure up the distance from spigot bearing in the crank, to the bellhousing mating face on the block. Take off the thickness for the metal spacer plate from this dimension. Now measure from the mating face of the bellhousing to the start of the spigot shaft, figure out the difference between them and hey presto! You now know what dimension you need to mill your factory bellhousing down to... minus a bit extra for the alloy plate you have to weld on and drill out to make it bolt to the VH engine.
The manifold looks to be the easy part... just make a plenum style tube for each side with runners intersecting them, use a couple of bends at the front of the motor to duct the tubes 90 degrees towards each other & meet in the middle, and weld in the final piece of tube where they meet to duct to the flange of the turbo. Weld in your O2 sensor thread somewhere at the front, and weld in somewhere for the wastegate to go.
I'd make urethane mounts for the motor, steel is going to twist your chassis with the amount of torque that motor will produce.
Basically, you've taken on a massive mission. I've been working on my manual converted VH41 V8 conversion for 9+ months now. It's nearly ready, though it fit into my choice of car a hell of a lot easier than a VH45 in an S15. I don't envy your mission, but it'd certainly be awesome if you pulled it off.
Just be aware of one thing, conversions always end up going to nearly twice your budget.
gdz1la wrote:can you help me out with a few things then. im on a very tight bugeti have a 26/30 allready if its going to cost over 1000 ill prob passi need
z32 starter or similar... skyline?flywheel to suit... and someone to adapt the bellhousiung & a rb osgikin triple plate clutch...
make manifold.. looks so stressfull i dont know even where to start.make mounts, it looks like a 2*6' block of urethane make work or should i use alloy or steel?once that donev mount coolers mount turbo somewhere?? to allow a 3.5" exh to pass to rear (im really struggling for room now)
anyone wana trade for a 41??
