Q45 Ignition Switch Removal and Replacement
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
Can steering wheel Ignition switch be removed and replaced! If so send me in the right direction on how too! Is there a step by step available for Q's? I have done Ignitions in other makes and models before but, Q's are different a lot of times on certain things.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There is a post on the dash, and I think one on the ignition switch also.
Did you search?
Q451990
Very straight forward process. Remove cladding... there's a u-shaped bracket on the bottom of the column that holds the top half in place. The only question you'll have is how to remove the screws. They are shear-head security screws, so you have to drill them out. If you want to re-use it some security torx or cap head alen screws could work...
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The guys at T3 recommend getting your dremel out and cutting a notch in them to take them out with a screwdriver.
Q451990
I seem to remember them being recessed into the holes, but I could be wrong. The metal was fairly soft and easy to drill out, and the break-away heads leave a nice dimple to seat the drill bit...
Guess it's a personal preference thing.
Heath
PopPop
I appreciate all the information fellas!
3rd Q
Pop,Just did it on my parts car. Drilled a small hole in head of bolt and used a screw extractor bit - came out very easily. I'm sure the other ideas will work as well.
Paul
