miata007 »
https://forums.nicoclub.com/miata007-u31566.html
Thu Aug 11, 2005 7:05 am
Hello,
I have just joined the forum and hope to get some help on my 1997 Q45 I recently purchased. The car has gotten about 120k and has been dealer serviced since new. After I bought the car, I realized that it's got an idling problem, not sure if it is major or minor. When the car is in idle, the tach. meter shows around 700 rpm and it fluctuate +/-50 rpm at times (at times). The symptom is consistant so doesn't matter if the car is warmed up or not. If put in drive while the car is not moving or come to a stop, the engine dips all the way to 500 rpm and back to 700rpm (also happens sometimes). It feels like the car is about to stall when that happens but has never stalled. Driving on freeway speed, nothing is noticeable. It is very smooth and powerful when I floored the gas. But at speed from maybe 25 mph to 45, I can feel the engine rmp fluctuation is still there. Does anyone have any clue what is wrong with this car?
Talking to several Q45 owners, they have mentioned about the air flow sensor. This part is $300 to $350, I want to confirm if it is really the cause before I change it. Another thing that come across my mind is the injectors? or the coils? I am currently waiting for the service record from the dealer the car had serviced at. It's my fault to not check that before buying this car. Hope you guys can help. Does anyone have any recommendation for a good mechanic or shop(non Infiniti dealer) around the Sacramento area?
007
