handyandy123 »
https://forums.nicoclub.com/handyandy123-u219637.html
Sun May 05, 2013 2:06 pm
2002 Q45.
Hi guys..... my main drive belt slipped off last week and I had a heck of a time getting a new one on. However it slipped off again and I need a new idler pulley. I went to Napa and they gave me a 20mm wide one which shows its the correct size, (also advance auto had the same size 20mm width). Problem is that is too narrow for the belt...so it cannot be the right pulley size. Then Napa had a 32mm wide one and I grabbed that but that is for the other belt it seems.
I finally see one at Autozone that is 25.1mm wide...so I am hoping that is the correct one. Anybody have any info on this? When I took the old one off the bearings were worn out so that must have been making that squealing that i have heard for the past month. I thought it was the transmission but could that noise have been from that idler pulley? It was pretty wobbly.
So I will go buy for the third time the 25.1mm wide pulley at Autozone tomorrow and hope that it is the correct one. there is no part number on the one I removed from the car....and nothing in the service manual that shows dimensions for the pulleys.
Thanks for any help you can give!
Andy
