Since NICO search now rocks I took a gander (Funny word) at all the posts of the previous owner of my Q45.
I cleaned the EGR and tired to clean where the EGR mounts on the plenum and saw that its was clean, not clean enough to eat off (serious money required there) but fairly clean. I cleaned it some more and got what I could out of there and I also cleaned the EGR.
The above has nothing to do with the idle but goes to show how clean the plenum is despite last being cleaned in 2004. Thanks Mike
The Idle Air Control Valve was cleaned 2 years ago but its not spotless and a new gasket was used when cleaned. Thanks Mike
The Throttle Body was cleaned last year and was clean enough to eat off of (For free).
That said when I try to adjust the Idle Air Control Valve by pass screw to ~3.5 turns the idle goes to ~2000 RPM's. There are no vacuum leaks that I am aware of and the vacuum gauge read 20" Hg and was steady at that range.
So I ask please what could be the problem here?
Wes said it could be a small vacuum leak but I doubt it. Then again I do have a box of hoses from the previous owner. The previous owner didn't install those hoses because he said they looked fine at the time (Half a**
Please move to Q45 section.
