szh »
https://forums.nicoclub.com/szh-u149.html
Tue Jul 16, 2013 9:45 pm
Try a good balance on your tires too at a reputable place - using a force-balance system like the Hunter GSP9700.
If the problem goes away and comes back fairly soon (like within a few hundred miles ... certainly well less than 1k or 2k miles), I would agree that broken tire internals (belt, rubber, etc.) are a possible culprit - they shift around as the tire rotates and quickly unbalance the tire again.
BTW, what is the brand of tire? Are you using a brand/model with sufficient load capacity (at least 94 or higher - preferably closer to 98 or 100) and speed rating (at least H or better)? And keeping the tire pressure at around 36 psi or so (plus or minus no more than 1 or 2 psi)?
Z
