Q45 high idle
revil86
Car: 1993 Infiniti Q45
ive noticed that the idle on my 93 Q has been goin nutsim not talkin about it going up and down, i mean like on a cold start it will idle at like 500 rpm, then i turn it off and back on again and its at like 1700 rpmive done some searching but i didnt find too muchsome people suggest its the throttle position sensor, some others say its the mass airflow sensorsomeone suggested to check the vacuums for leaks or whatever but i see nonedoesn anyone know any possible problems or solutions? and can someone explain that way without using lotsa acronyms, its kinda confusing, im no mechanic
revil86
update: i cleaned the MAF sensor and throttle body, no progress, on a cold start, it idles at like 500 RPM in park.i really hope its not the throttle position sensor, some places want $150 for it, i get $7/hour i cant afford that
CrimsonQ
Car: Purple People Eater
sell some stuff from your sig then
revil86
yea right, it might not be the best stuff, but its all i got
revil86
another update:while i was gettin my new control arms put in, i asked my mechanic whats the deal with this idle, he said its something like an idle control motor. he said this longer name for it but i forgot it, he pointed to it near the throttle body, it was black like the MAF sensor. he said you can try to clean it, anyone know how to go about that?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Does your Q have TCS??? If so maybe thats what he was thinking of, thats not it......
revil86
it does have TCS, are you suggesting that it is not the culprit behind the problem?
draivar
Car: 1991 Q45
any progress on this issue or *was it* just let go off???
elwesso
2007 BMW M Coupe
The car shouldnt idle that low when its first started.
Q451990
Another possibility is that the ECU temp sensor is bad or has a corroded connector. That could cause the ECU to think the car is warm even when it's not. I would certainly check the Idle Air Control Valve (IAC) (a/k/a AAC) too.
Heath
Aus94Q45
Car: 1994 Q45
Do you have the FSM? It names the idle control motor and the IAC Valve as places to check for fast idle issues. There are diagnostics listed there. How is the idle once it warms up?
elwesso
2007 BMW M Coupe
The idle valve shouldnt have any control over the idle when the car is cold... Very interesting indeed.
Aus94Q45
Car: 1994 Q45
Its tied into the entire system via the ECM and controls the overall idle. See pp. EF & EC 24 in the 94 FSM. But your right in that the FSM points to the fast idle cam on the side of the throttle body and to check for air leaks.
draivar
Car: 1991 Q45
mine starts out at about 900 rpm when first started///then as it is warmed up and of course revved a bit///will run up as high as 2200 rpm in neutral and of course jumps down a bit when put in gear....just did the plenum job a week back, i think i need to adjust the TPS....its just that i have tried twice to manually adjust but still get nothing...
now that the starter issue has risen, i gotta get that thing resolved before i hit the idle issue!!
redmanfx
Car: 92 Q45a
TPS is 120 something from Joe. IT's best to see if it's throwing a code before you go buying it though. Take it to a mech that has on consult to hook it up to. Mine did the same thing when it was going bad.
revil86 wrote:he said this longer name for it but i forgot it, he pointed to it near the throttle body, it was black like the MAF sensor. he said you can try to clean it, anyone know how to go about that?
That sounds like the TP Sensor he was talking about. Never tried to clean it though.
red
