CoastyAV8R »
https://forums.nicoclub.com/coastyav8r-u31435.html
Mon Aug 22, 2005 4:07 pm
My 94 Q45 seems to stumble pretty noticeably when trying to accelerate once the car is warm. When it's cold it runs fine. Once it does warm up, if I shift it myself and keep the rpms' over 2500, it doesn't do it very badly but still slightly noticeable. Once you get to 4000 rpms, it accelerates fine. If you give very light throttle applications, the car will acclerate but anything more than 1/8th throttle and the stumbling starts and will continue until the RPM's build over 2000-2500 rpms. The idle on the car is fine and it starts right up, hot or cold. From what I have read, it sounds like a MAF. I have cleaned the throttle body, MAF and the MAF connector 2 times and even though the throttle body was dirty it didn't solve the problem. I hate to throw parts at something unless I have either a troubleshooting flow chart or somebody has had a similar experience and can atleast let me know if I'm on the right track. I ain't got no flow chart so I'm hoping somebody will chime in...
Thanks,Pat
