Q45 help, will start but it wont rev
drifterdevin
Car: 1985 toyota corolla, 1991 nissan 240sx, 1994 nissan sentra, 1991 infiniti Q45
Well I tried using my good fuel pump controller on the problematic Q45, that did not fix it and the fuel pressure was tested, it was fine
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
drifterdevin wrote:.....the fuel pressure was tested, it was fine
Please define "fine" at idle and WOT.
Q45tech
You must measure fuel pressure UNDER LOAD on the highway not just sitting still. There can be a 50- 100 TIMES difference in fuel consumption at warm idle in Park and peak consumption during WOT acceleration on the road.
The difference between 34 psi and 43.4 psi represents only a 13% difference in injector flow rate......................it is all about 1 millisec vs 11 millisecs open time and a 10x rpm increase [650>6500].
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
How does one check fuel pressure on the road? Would that be something that could be done with a Consult or Blazt?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
You get a long enough piece of rubber hose and then cut it in 2 then attach everthing up properly then tape to the windshield.
Neither laptop consult or the real Consult (To my understanting) are capable of reading or calculating the fuel pressure.
Haitian_King
Paul Wall wrote:You get a long enough piece of rubber hose and then cut it in 2 then attach everthing up properly then tape to the windshield.
So it's just an extension of the fuel line? Wouldn't that change the pressure reading since the length of the fuel travel pattern is longer? Would it be the same as OEM, or would you have to recalculate to allow for the longer fuel lines and draw your conclusions from there?
