"Nissan/Infinity Q45 4.5-litre V8 (VH45DE)
A-ha! Here's the monster of the group! Rated at more than 200kW, the VH45DE is Nissan's top-line 'VIP' engine that's a mechanical tour-de-force. You can quite literally fit your entire hand inside this throttle body - its 75mm bore is by f-a-r the biggest we've sampled. Ignoring the throttle blade, this unit gives a sensational cross-sectional area of 44.2cm2. We were unable to accurately measure its bolt pattern, but it is an offset square arrangement with less than 80mm from bolt centre to centre. You'll need a big feed pipe to connect to this bugger - its inlet pipe is a humungous 90mm in diameter! This is a brilliant throttle body if you can find one - Adelaide Japanese Dismantlers suggests you'll pay around AUD$150 for this rare beast.
Bore Diameter 75mm
Bore Cross-Section (Ignoring Throttle Blade): 44.2cm2 (Rank 1st)
Overall Length: 109mm
Bolt Pattern: Four bolts - offset square pattern
Inlet Pipe (OD): 90mm round"
copied from :
http://autospeed.co.nz/cms/title_Thrott ... ticle.html
