MisterQ:
Here is a particularily comprehensive parts list for a guide job.A few of the parts here are actually optional, but they are all the current parts.
As you see your parts# is in it.
2x 01121-04711 - bolts for new guides 4x 11051-60U04 - cam end seals 2x 13021-60U00 - crank/cam sprockets 2x 13028-60U00 - timing chains 1x 13070-60U03 - chain tensioner(RH) 1x 13070-60U12 - chain tensioner(LH) 4x 13075-60U02 - tensioner bolts 1x 13079-60U01 - tensioner gasket(LH) 2x 13085-60U01 - chain guide <----------------!2x 13085-60U11 - chain guide <----------------!1x 13091-60U01 - guide(tension RH) 1x 13091-60U11 - guide(tension LH) 2x 13094-60U00 - guide bolts 1x 13510-60U00 - front cover seal 1x 15041-60U00 - oil pump chain 1x 15043-60U00 - crank/timing sprocket 1x 15044-60U00 - crank/oil sprocket 1x 15072-60U00 - bracket oil pump 1x 15073-60U00 - oil pump chain guide 1x 15073-60U10 - oil pump chain guide 2x 13270-60U00 - valve cover gaskets
Good luck,Daedalus our online mechnic here, has dopne the chain guide job several times, so be sure to post any other questions you might have here.
Fred...
