Q45 Guides listings
jefftrexler
Car: 1991 Nissan Maxima
Before the great upgrade of the NICO forum there was a list of all the parts that are required for a timing chain guide job on the 1st-gen Q45s. Anyone here know where I can find this parts list, and if possible pricing on those parts? My Q is showing signs that it has jumped timing....and its got me greatly concerned. Please let me know!!! :eek:
PalmerWMD
Car: 2004 350Z
Jeff:
2x 01121-04711 - bolts for new guides 4x 11051-60U04 - cam end seals 2x 13021-60U00 - crank/cam sprockets 2x 13028-60U00 - timing chains 1x 13070-60U03 - chain tensioner(RH) 1x 13070-60U12 - chain tensioner(LH) 4x 13075-60U02 - tensioner bolts 1x 13079-60U01 - tensioner gasket(LH) 2x 13085-60U01 - chain guide 2x 13085-60U11 - chain guide 1x 13091-60U01 - guide(tension RH) 1x 13091-60U11 - guide(tension LH) 2x 13094-60U00 - guide bolts 1x 13510-60U00 - front cover seal 1x 15041-60U00 - oil pump chain 1x 15043-60U00 - crank/timing sprocket 1x 15044-60U00 - crank/oil sprocket 1x 15072-60U00 - bracket oil pump 1x 15073-60U00 - oil pump chain guide 1x 15073-60U10 - oil pump chain guide 2x 13270-60U00 - valve cover gaskets
This is the dealer parts list and includes chains.W/o chains I think its about $450 from Scottsdale.
Keep us posted.
Fred...:)
jefftrexler
Thanks for the listings!!! One thing though....is there any way to get individual pricing on the parts? I would greatly appreciate it. Thanks!!! :ylsuper
PalmerWMD
Car: 2004 350Z
2x 01121-04711 - bolts for new guides NA4x 11051-60U04 - cam end seals NA2x 13021-60U00 - crank/cam sprockets NA2x 13028-60U00 - timing chains $99.881x 13070-60U03 - chain tensioner(RH) $49.901x 13070-60U12 - chain tensioner(LH) $49.904x 13075-60U02 - tensioner bolts $ 5.201x 13079-60U01 - tensioner gasket(LH) $ .562x 13085-60U01 - chain guide $13.182x 13085-60U11 - chain guide $13.181x 13091-60U01 - guide(tension RH) $49.851x 13091-60U11 - guide(tension LH) $49.852x 13094-60U00 - guide bolts NA1x 13510-60U00 - front cover seal $ 5.341x 15041-60U00 - oil pump chain $33.881x 15043-60U00 - crank/timing sprcket NA 1x 15044-60U00 - crank/oil sprocket $33.881x 15072-60U00 - bracket oil pump NA1x 15073-60U00 - oil pump chain guide $ 4.871x 15073-60U10 - oil pump chain guide $30.852x 13270-60U00 - valve cover gaskets NA8x 14032-60U01 - intk manifold gskts $24.80
Theses prices are 2 years old.
Fred..:)
jefftrexler
I called over to Scottsdale Infiniti and spoke to Scott to get updated pricing on the parts that Palmerwmd had listed. The listed prices are for NICO members and are as follows...
2x 13028-60U00 - timing chains $54.511x 13070-60U03 - chain tensioner(RH) $49.901x 13070-60U12 - chain tensioner(LH) $49.901x 13079-60U01 - tensioner gasket(LH) $ .562x 13085-60U01 - chain guide $7.192x 13085-60U11 - chain guide $7.191x 13091-60U01 - guide(tension RH) $54.431x 13091-60U11 - guide(tension LH) $54.431x 13510-60U00 - front cover seal $5.431x 15041-60U00 - oil pump chain $37.011x 15073-60U00 - oil pump chain guide $5.311x 15073-60U10 - oil pump chain guide $33.68
forecast
Jeff,
If you are getting the work done at a shop - get an estimate first! Consider:
a normal guide change involves one engine cover and 8 hours for a competent tech.
Your story sounds different - if you believe a chain has skipped a tooth, it will require two things - a full timing reset - 22 hours and dropping the pan to clean out the bits of the chain 20 hours. If your shop charges a humble $50/hour - thats close to $2k in labor. Parts and labor together can easily exceed $3000.
Of course you could be wrong. The tech might pull the front cover to discover the guides still in place (meaning the timing won't be off).
Of course, if you are doing the work yourself - great! Your times may be a little longer, but it will be so satisfying to hear the engine start over when you get it all done.
What year and how many miles does the car have? Do you know the service or ownership history? What sighs do you have of a skipped chain.
If the symptom of bad timing was that the car started running rough and a timing light suddenly showed the spark off by 20 degrees - don't drive it anymore!
dan
jefftrexler
Well all the tell-tale signs of the guides going is evident. The worsened gas milage...the bad idle (smooth for a little bit...then a bit jumpy the next)...a little knock towards the front of the engine. Yea....its all there. :(A friend (who is awesome with Nissans and Toyotas) will be doing the chain guides with my help. The cost for install? $100 and a pizza! Through a contact of mine its looking like the guides, tensioners and oil chain will end up costing me only $180. Not too shabbeh if you ask me! :D
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
That's a good friend!
forecast
amen to that!
I'm really curious, when you friend has it open let us know if was off time or not.
