Q45 Goodies
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
Hi, here's some more info, my Company BELLEZA has made arrangements with various factories to produce High Quality OEM exceeding parts for Nissan / Infiniti cars, 2 of the many goodies I have to sell are Suspension and Brake Kits, I need testers for both, there are only 15 spots available to get these at a special Discounted "Tester's price", will need the old ones though for studying, the names you see on the parts are a place holder for my company's name just so I can see what they look like.
Shocks to choose from:
LS : - Applied general shape springs: has a good effect on car height adjusting by vertical coil spring.
- Individual piston: individual piston can completely separate oil and gas thus keeping the damping force.
-Double tube structure: high speed series shock absorbents all possess single tube structure for higher radiation and inhibit oil viscosity changing, and minimize damping character changing.
RS2: - High strength spring: has Japanese high quality and strength material, “SAE9254,” the diameter has been minimized, but the dense coil can still keep the appropriate stroke and yield a lightweight and comfortable riding feeling.
RS3: - In accordance with the individual stages can stretch adjustable damping technology.
- Adjust the height according to personal needs
- Construction elements giving a high value long life.
- The complete archives give a simple application.
- Unique, and each operates independently adjust the damping force.
N1: - 24 position strain/compression damping force adjustable mechanism helps to give consideration to hard driving and
comfortableness, as well as superior performance. Meticulously designed damping valve van precisely control the
feedback force and handle all kinds of road situations.
- The dust cover made by a special resin material, it can fully protect from the shock absorber rod
against dirt, dust, rain and extend the shock absorbent's life and durability.
- N1 style applies newly designed spring fixing base, and has set on the best position when leaving the manufacturer. Please
check if the spring has been loosened after resetting the spring position.
- Inbuilt in tube valve: unfavorable vibration is mainly caused by the feedback of gas pressure. Though under high speed, the
tube valve and high damping setting can cause a lower gas pressure ratio, ensuring a comfortable ride and minimized
vibration.
- Large piston diameter: single tube structure helps to enlarge the piston diameter to 45f A arm (40f), and the larger pressure
responding surface can increase the valve’s initial response.
N1-R: The top technology for the sports style drivers. This mutual separation and can be independent adjust of the uphold side and compression side damping can be designed in accordance with all types of vehicles dedicated to its damping setting. This unique system achieves the traveling at low speed range set in the compression side damping during the three control loops, while in the comfort of high speed range is fully multi-adjustment feature. It can absolutely satisfy your most extreme requirements.
Suspension comes with a 1 year warranty
BRAKES
You have options of Rotor Thickness, drilled, Slotted, Wavy, or all 3, and plain, it is a 2 piece rotor, 6 piston calipers. Kit includes full assembly including brackets.
Colors to choose from:
94Q45Beast
1992 INFINITI Q45
The website is being developed (by me) and that will make it a lot easier to pay, but for now i'll give you my company's address for you to submit a payment through paypal where the buyer is also insured
What I'm Looking for:
- ease of installation
- stopping distance from 85mph, 65mph, 55pmh, 45mph, and 30mph
- how long it takes to wear out the pads completely and the conditions you drove in. (minimum pad thickness is the same as what is listed in your fsm)
- precise rotor thickness after brake pads are used up
- Exact model of your Q45,year, date manufactured, & mileage
- and your overall thoughts on the brake kit.
- body roll
- dampening
- ride quality
- traction
All brake kits and suspension kits are assembled to order to ensure quality and customer satisfaction of a team of skilled master machinists putting together your order.
Disk size to choose from:
286mm, 304mm, 330mm , 356mm, 380mm, & 405mm
Disk specs to choose from for 2 piece rotors (with hats):
Plain, drilled, Slotted, Wavy, Drilled & Slotted, Drilled & wavy, Slotted & wavy, plain & wavy, or Drilled Slotted & wavy
Price is $2000 for all 4, includes shipping, NICO members get 15% off, Tester's price is $1475
All testers will get 25% off on carbon ceramic rotors + pads, and upgraded Brake master cylinder and additional 15% off for testing those.
address for payment will be provided in the classifieds upon pm requests to enroll
Sincerely & Respectfully
BELLEZA MOTORS, website is under development
HansCC
Car: 1999 Y33 Cima
So I noticed the shock kits with no spindle? Getting setup with a q45 98/2001 on the BC Coilovers and some others it's recommended you get the setup with the spindle. You have any comments on that or are all these parts 3rd gen? Thx - (did I miss the generation?)
ldillow
I need shocks, was considering stock ones, but would be happy to be a tester. My other car is an M3.
ldillow
Forgot, my car is a 1999 q45 with 165k on it.
It is definitely growing on me!
94Q45Beast
1992 INFINITI Q45
I apologize, been a way for a while, I needed some time off, my cousin who was like a little brother to me died unexpectedly, I'm still not ready to pick up where I left off, still need some time....
HansCC
Car: 1999 Y33 Cima
Sorry to hear about your loss - we are all hoping you have something with the spindle for us q45T peeps - Let us know when you get back - Best Regards and our sympathy;
H.
94Q45Beast
1992 INFINITI Q45
I sent you a pm, I thought about it for a while....and after seeing a growth spurt of Y33's here in Atlanta now that I'm back, I can have the spindle made with no problem, just send pm with pictures of the spindle with the entire assembly removed and I'll give you a price quote for everyday, OEM match shock assembly....without the adjustable dampening and height adjusting and all the other stuff.
bigdavesned
Sending you peace and condolences for the loss of your cousin. If you are back at it, I have a 94 Q45 with 99,000 miles and considering suspension. Are you still looking for testers? Thanks.
94Q45Beast
1992 INFINITI Q45
all testers spots are filled up unfortunately, my COO filled them up when I was away, I am back, soon as you get 10 posts, pm me with pictures of your suspension assembly and the type of suspension you want.
