elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue May 06, 2003 2:58 pm
If your feeling up to the challenge, you could take off the TB (only a couple hoses to take off), and reach inside the plenum with a rag doused in carb cleaner, and that should do a pretty good job. Also, clean the TB while your at it.
I just did something yesterday that may help (I am not an experienced Q owner, so we may need someone else to chime in and correct me). Take off the intake hose and spray TB cleaner (i got some valvoline air intake/TB cleaner from advance) inside there (engine off), moving the throttle back and forth. TB cleaner will start running out of the TB, and just put a paper towel to catch all the gunk infested cleaner. If you want to go over and beyond, take off the lower vacuum hose, right under where the intake hose meets the TB, and with the engine running, spray some TB cleaner in there, being careful to keep the RPMs up as not to stall it.
