Q45(G50) Knurl size? 13mm? 14.3? staggared F/R? an explanation has been added.
jtmroczk
Car: 2010 6-speed FJC, 1994 6-speed Q45
the question still stands on the Knurl size for the Q45 and explanation is below for those of you who do not know the term. If you have ordered and installed you own studs your input is welcome, thanks. I'm not worried about thread size and pitch.
elwesso wrote:what are you talking about? Ive never heard that term?I know that the studs across the board for nissan are the same...
the Knurl is the splined end of the wheel stud that seats into the hub.
Nissan uses a 13mm diameter and a 14.3mm diameter on S and Z chassis cars.
If you still don't understand please don't Lock my thread, read about it from SPLparts.com or where ever you would like.
ARP wheel studs are made from heat treated chromoly steel and have a 190,000 PSI tensile strength rating. These studs are much stronger than stock studs, and are available in 2 sizes to fit Nissan hubs: 14.3mm knurl studs are 15mm longer (fits Z32 front, S14 front, Z33 front and rear)13mm knurl studs are 20mm longer (fits S13 front and rear, S14 rear, Z32 rear) Note: Installation of rear wheel studs on cars with e-brake assembly requires removal of the wheel hub. Note: Requires open ended 12mm x 1.5 pitch lug nuts. Please see our Gorilla spline drive open ended lug nuts for use with these wheel studs.
Sold as a package of 10 studs, with hardware (nut & washers) for installation.ARP wheel studs (set of 10)Type:
Q45tech
WRONG FORUM BELONGS IN VIP SECTION!
