Q45 Fuel pump questions
DebbiQ
Car: 1992 Q45
Hi,We have a 1990 Q parts car. I like to keep everything moving under its' own power as much as possible, fuel pump just conked out.
Getting power thru the relay. Ohmed the pump per the FSM shows 1 ohm, not .5 as speced. Is the pump toast? Would it be worth trying to bypass the fpcu to see if it may work? This is only a parts car.
TIA
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
You could bypass the FPCU to see if the pump works but chances are that it is also on its way out.
Usually a failing pump is what kills the FPCU. The pump might work but it would probably be very noisey which is an indication of its death agony.
DebbiQ
Car: 1992 Q45
Thanks, it's only a parts car, if it will move a few more times I'm happy.
I have read 5 thousand references in the archives to attaching a jumper to ground the fpcu, but no specific instructions.
Can someone tell me how to do this?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It's in a Q45tech post, among others. Look at your FSM. You are just jumping to ground.
96Qowner
Car: 1996 Q45
Here's the thread detailing how to jump the FPCU:
zerothread?id=18148
DebbiQ
Car: 1992 Q45
Appreciate the replies.
Thanks especially 96Q Owner. Tangalora explained it graphically and simply, so your link was a huge help.
Now my parts car can at least move from here to there when needed.
Alan
