tangalora »
https://forums.nicoclub.com/tangalora-u10548.html
Tue Sep 02, 2003 9:27 am
> The only thing that looked out of > place was a yellowish substance> which appeared to adhere to a> copper colored circular doohicky
The biotech guys at the hospital I work for told me that yellow stuff is merely silicone vibration protection for the copper coil inductor on the FPCU PCB. That is apparently quite normal. It's in my FPCU also.
What you might wish to test is the resistance between the FPCU ground connector (the male pin labelled #4 on the printed circuit board) with any other solder point on that ground-wire trace on the PCB. Mine, for example, read infinite ohms until we re-soldered the fuel pump control unit connector pin #4 back to the PCB. (We added an additional jumper for insurance.) Now it reads 0.01 ohms from any point on that ground trace to any other point to pin #4 on the fuel pump control unit connector.
For debugging the FPCU, you _could_ follow the (tedious) suggestions in the FSM (which outline the use of a 4,5, & 6 wire connector created for a test jig between the white male fuel pump control unit connector and the white female fuel pump control unit harness connector) as per EF & EC-186).
Or, you could just follow q45tech expert advice which I accomplished by filing an alligator clip's teeth down (one side necessary only) so it just fits into the corner female terminal of the fuel pump control unit harness connector and then attach the other end of the alligator clip wire to any convenient ground. In my case, when the ignition was turned on, the fuel pump started humming for the first time in more than two weeks. The 16 AWG jumper wire I picked up from a friend in the lab does NOT get hot to the touch after a 20-mile ride in a mix of highway & local streets, so I assume the amperage to ground is low (electrical advice always welcome).
I am keeping the fuel tank full all week as I limp along with this workaround (as per fuel-pump cooling recommendations in this web site & at Yahoo). Funny. I haven't bought 2 or 3 dollars worth of gas so often since I was a teenager (a long time ago when fuel pumps were mechanical & bolted to the engine in my Dad's '67 Chrysler New Yorker 440 engine).
The critical secret, it seems, is to jumper the correct wire, which being fried in my case, revealed itself to be the lower left corner female terminal in the fuel pump control unit harness connector (facing the terminals with the tab at top).
