Q45 Fuel pump = 300ZX Twin Turbo Fuel Pump?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gawath
Is the 1990-1994 Q45 Fuel pump the same one as the 1990-1996 300ZX Twin Turbo fuel pump?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yes sir.
gawath
Is there any confirmation on this. EX: Pictures of them side by side, part numbers, etc.
Raxephon
Car: '04 RX8...for the moment...
gawath wrote:Is there any confirmation on this. EX: Pictures of them side by side, part numbers, etc.
Yep.
If you search the older threads, take some time, read a little, you should find the reassurance that you need that they are the same.(I'm not trying to be an a$$, its simply what I've done in the past in my search for parts compatibility)
Part numbers will be slightly different since the Q45 is from Infiniti and the 300zx is from Nissan.(Even though they are both really just Nissans)
Avoid buying used if possible, most used ones will not last very long if they work at all.
Return to “VH45DE / VK45DE / VK56DE Forum”
