Q45 fuel problems
breda43
Car: Infinity Q45
My Q45 shuts down but can be restarted when driving.I was told if I hear a loud noise from the fuel pump,this is the problem and I should fix before FECU shorts or overheats.IS THIS TRUE!
Q451990
Absolutely... although it sounds like it may already be too late if it's cutting off on you. How many miles on your Q and how many miles since your last fuel pump replacement? Do you hear a humming noise from behind your back seat - especially when the gas is below half a tank?
Heath
breda43
Car: Infinity Q45
My Q45 has 205,000 origanal miles and same fuel pump.I've replaced the ECU at 125,000. Yes I do hear a humming noise.
redmanfx
Car: 92 Q45a
Change the fuel pump and DO NOT BUY A USED PUMP! Make sure you replace the bad pump with a new one.
red
breda43
Car: Infinity Q45
Thanks for the info.I will do exactly that.Who has a good price on fuel pumps for a Q45?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
One of our sponsors.
I am particular to http://www.everythinginfiniti.com
Be sure to look at your tank as it probably has some debris (maybe microfine) floating around. If it does, be prepared to remove it for a steam cleaning.
Don't for get the O ring and to at least blow your fuel lines out, and replace the filter.
breda43
Car: Infinity Q45
Do you have to remove fuel tank on Q45 to perform feul pump removal and can you buy a rebuild kit?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You definitely want to buy a new pump!
the I ring is designed to expand over a certain period of time. be sure to replace that, I didnt listen and I had gas smell!
