Q45 front struts
kdurham
Looking for 98 Q45t front struts, does anyone know of a place other than the dealer who want $413.00 per strut... Thanx!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.everythinginfiniti.com
One of our fine sponsors.
Modified by maxnix at 11:03 PM 8/24/2006
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
Don't buy the whole strut assembly if yours isn't bent or going bad. The insert costs $107.54 each. Direct link:
http://www.trademotion.com/par...gid=2
bballmike
Car: 1997 Infiniti Q45
The direct link doesn't work, but the Everything Infiniti link in the previous post is actually the Trademotion site. I found the whole strut assembly, but can't find just the Insert.
The problem I'm having is the left front strut moves within the strut mount about 1/4" when I pull/push the top of the wheel when the car is on the ground. The nut is tightened down. Its like the Insert has slipped up a little in the strut casing. Is this possible?
Then, would I need the whole strut assembly?
cullenj76
Car: 99 Q45t 04 SRT-4
Sounds like a bad strut mount to me
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Infiniti-parts.com has inserts for about $125 and strut mounts for about $75. Various rubber parts are also needed. Check out their site and you'll see.
bballmike
Found the problem: Strut mounts. The rubber had worn/dry-rooted and broken away from the strut mount causing the strut to move around freely within the mount. New mount from dealer at $60 and $3 bushing fixed it. Now, off to the alignment shop.
Thanks for the input.
Mike
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
IOS knows all this and is an invaluable resource.
