Q45 (FGY33) Touring / Active Suspension Shock & Spring Setup
TheDeadKing
Car: 1994 Nissan 300ZX & 2001 Infiniti Q45t
For Q45 owners with active suspension looking to lower and/or overhaul worn stock suspension, but don't want to install coilovers due to diminished ride quality (added stiffness/harshness), there is another option. Shocks and springs are much more time and labor intensive and the cost(s) vary depending on where you source the parts, but I feel that the end result is overall a better option. I used a combination of infinitipartsdeal.com, nissanpartsdeal.com, fromjapan.co.jp/en/, blackhawkjapan.com, rhdjapan.com, rockauto.com, partsgeek.com and ebay.com to source the necessary parts due to price or availability.
FRONT SUSPENSION
NSC6004 (KYB SR SPECIAL FRONT STRUT SHOCK ABSORBER) x2
N183D (RS-R DOWN SUSPENSION FULL SET)
54302-3H920 (Strut Kit-Front Suspension,RH) x1 REUSE
54303-3H920 (Strut Kit-Front Suspension,LH) x1 REUSE
54330-4P000 (Cap-Front Strut Insulator) x2
54329-10V00 (Spacer-Front Strut Insulator) x2
54320-3H900 (Insulator Assy-Strut Mounting) x2
54322-4P701 (Bracket-Front Strut Mounting Insulator) x2
54325-4P001 (Bearing-Strut Mounting) x2
54040-4P001 (Seat Assy-Front Spring, Upper) x2
54050-4P702 (Bumper Assy-Bound) x2
54034-4P000 (Seat-Rubber, Front Spring) x2
55031-6P100 (Tube-Spring) x2 REUSE IF POSSIBLE
My one owner 2001 Q45t has 105,000 original miles, so I was able to reuse some of the original parts. For people with cars that have significantly more miles or wear, you should expect to buy new tube springs (55031-6P100).
There are cheaper strut mount (54320-3H900) options, which include the strut bearing (54325-4P001), on rockauto.com. I personally used GABRIEL (143210) strut mounts, but opted to use the OEM strut bearings (54325-4P001) due to quality. According to the photo, the KYB (SM5328) strut mounts seem to include a better strut bearing than the one provided by GABRIEL making them potentially a better option.
When uninstalling the whole OEM strut bodies (54302-3H920 & 54303-3H920), I had issues unbolting the nuts on the stabilizer bar end links (54618-6P001 & 54668-6P001) on both sides; I had to cut one of the nuts off and use a dye to clean the threads. It might be a good idea to replace these, especially if you run into problems like I did. With everything disassembled, I took the opportunity to replace the ball joints with a pair of new old stock MOOG K9818 ball joints that were made in Japan.
FYI use a drain pan to catch the fluid when you unscrew the large nut to take out the OEM strut insert from inside the OEM strut bodies (54302-3H920 & 54303-3H920). After draining the fluid, use either suspension fork cleaner or brake parts cleaner to clean the inside of the OEM strut bodies of all residual fluid. The KYB front struts (NSC6004) are sealed assemblies, so you DO NOT replace the fluid when installing the KYB struts into the OEM strut bodies. The KYB struts come with a thick spacer that fits into the bottom perch of the KYB struts; I secured them together with electrical tape and installed them into the OEM strut bodies. In addition, the KYB struts come with a new large nut that you will use to secure/seal the new KYB struts into the OEM strut bodies.
REAR SUSPENSION
NSG9069 (KYB SR SPECIAL REAR STRUT SHOCK ABSORBER) x2
56204-60U00 (Cap-Rear Shock Absorber) x2
56217-61L10 (Bush-Rear Shock Absorber) x2
55338-60U00 (Seal-Mounting, Shock Absorber) x2
56217-39U00 (Bush-Rear Shock Absorber) x2
55322-4P701 (Bracket Assy-Mounting, Shock Absorber) x2 REUSE
55323-2Y000 (Tube-Distance, Shock Absorber Mounting) x2 REUSE
55034-0P000 (Seat-Rubber, Rear Spring Upper) x2
56218-61L10 (Bush-Rear Shock Absorber) x2
55248-2Y00A (Cover-Bound Bumper, Rear) x2 REUSE
55240-0P000 (Bumper Assy-Bound, Rear Suspension) x2
55031-41L00 (Tube-Rear Spring) x2 REUSE IF POSSIBLE
The Q45's with active suspension use shock absorber bushings (56217-39U00 & 56218-61L10) that are reinforced with a metal tube insert (55323-2Y000), whereas Q45's that don't have active suspension use shock absorber bushings (56217-61L10 & 56218-61L10) that are not reinforced by a metal tube insert. There are two part numbers listed for the shock absorber bracket mount (55322-0P000 & 55322-4P701), which I was unable to tell the difference between the two. I decided to reuse my original shock absorber bracket mount (55322-4P701) with the active suspension shock absorber bushings (56217-39U00 & 56218-61L10) and reinforced metal tube insert (55323-2Y000). When I checked for the active suspension shock absorber bushings, I saw they are discontinued/NLA on infinitipartsdeal.com; however, you may be able to find them elsewhere. If not, use the shock absorber bushings for the non-active suspension Q45's and discard the metal tube insert. There are several OE shock absorber bushings options listed on rockauto.com.
Regarding the front and rear OEM actuators that sit on top of the factory active suspension shocks, I disconnected and removed all four without throwing a code or a dash light.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Impressive post.
Bernie (NoVA)
Car: 1995 Nissan 300ZX TT
1997 Nissan 240SX
The difference between the rear perch between the active and standard suspension is the opening hole in the middle is larger for the active suspension because the metal sleeve/tube that passes through the middle of the 2 bushings.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
nice write-up, and including part numbers is a useful reference for future do'ers.
I think you are wise to use the nissan pedigree strut bearing. I'd also note that the strut mount (hat) may not have been 100% in the original design, as I had one on my '97 that the rubber 'mount' separated from the metal frame. Back in 2005, when I replaced mine, the part number was -6p010, which indicates a revision from the original -6p001. Presumably the 'defect' was addressed by the countermeasure part. Moog/Gabriel may or may not be based on the revision.
One tip on reusing the casing nut over the new front cartridge inserts is to make sure it's a) not cross-threaded, and b) tight! like use a plumbers wrench. If you find yourself needing to tighten it after the coil spring is installed, it ain't easy.
If the 55031- sleeves are not reusable, and you don't want to buy new ones (haven't even looked to see if they are still avail), might consider using some spray rubber after a good cleaning and let it fully cure before reassembling. I don't often advocate 'work around' solutions, but the idea is to prevent metal on metal squeeking contact. just sticking an old piece of heater hose in there will be too sloppy.
Here's my original write up from 2005. Picture links long disintegrated....sorry.
post1103852.html#p1103852
Yes, I also had to hack the nut off the sway bar end link. part number for the new nut is: 08911-6421a
TheDeadKing
Front Suspension
TheDeadKing
Rear Suspension
fivehole70
Car: 2000 Infiniti Q45t
I'm looking for help to verifying the correct part number for my 2000 Q45t. My question is besides the trunk badge with the t, how can I verify I have the Touring package? If the car has the Auto Sport Suspension ride control switch, then does that mean it has the Touring package? I ask because the price of the struts on Amayama for the Touring version is twice as expensive as the non-touring. Thank you!
Ludeaem
Car: 2000 Infiniti Q45 AE
Easiest way is to open your hood and on the shock towers there will be a semi circular module on top the shocks with a wire harness. Sure fire wire to know it has active suspension
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
fivehole70 wrote:
Fri Dec 06, 2024 9:25 am
From the 2000 INFINITI Q45 Press Kit
The Active Damping Suspension, available as standard equipment on the Q45t, offers electronically modulated shock valving control with SPORT and AUTO driver selectable settings.
The system uses real-time, independent 4-wheel shock absorber damping force regulation in response to input from vertical G-sensors and steering angle sensors. Signals from these sensors are sent to the system’s computer control unit, then matched with vehicle speed. “Instruction” data is then sent back to actuators above each individual shock absorber, which immediately adjust shock absorber damping force.
The system helps eliminate excessive body movement, as experienced during hard cornering, braking or acceleration. It also helps improve tire-to-road surface contact for greater stability and enhanced handling control. With the two adjustable settings, drivers can chose between a softer, more comfortable ride or a firmer ride with more road feel, depending on driver preference.
EDIT: The 2000 Q45 came in 3 trim levels, Base; Touring (signified by the lowercase t); Anniversary Edition (limited to 3,000 units)
Reason: Edited
fivehole70
Thank you to Ludeaem and Rogue One for taking the time to reply. I have confirmation mine is the Touring and now I am waiting to hear from Amayama if the front struts are available at $1600+.
Ludeaem
I have KYB inserts for sale that you can use! PM me if you'd like
fivehole70
Here's the response from Amayama:
"These parts came back as export parts, this essentially means that Nissan does not allow the parts to be exported from Japan. They can only be supplied through a dealer local to the export market that the vehicle was intended for. Unfortunately we cannot supply them as a result."
I'm disappointed, to say the least.
fivehole70
Ludeaem wrote:
Wed Dec 11, 2024 1:31 pm
Thank you for the offer. Unfortunately, I'm not a mechanic but I love this car and I was hoping to source the struts because the local dealership said they are not available.
Ludeaem
Its not difficult at all. Some threads on here on how to do it but even a basic mechanic would be able to do this swap. The rears are full bolt in and the fronts just take a large wrench to undo a nut and its a simple swap out of the cartridge. Either way, if you change your mind this will save you a lot of $$.
fivehole70
Ludeaem wrote:
Fri Dec 13, 2024 6:27 am
Thanks for the advice. I will ask my local independent Nissan/Infiniti shop if they'd be willing to do this.
Ludeaem
here is the thread that has front insert install pictures/guidance
1997-infiniti-q45-front-struts-kyb-sr-s ... 22749a5c41
fivehole70
Ludeaem wrote:
Sun Dec 15, 2024 12:30 pm
Thank you for the link to the thread. It has a lot of detailed info. If I find someone who is willing to do the job, I will reach out to get the new SR Special set.
Ludeaem
If you do decide don't forget to buy it from me :D
fivehole70
Ludeaem wrote:
Sun Dec 15, 2024 4:16 pm
I replied to your Facebook Marketplace ad.
