It was b**** to remove and replace the rubber return hose portion while the rack was still in the car, but I know it will be a breeze once the rack is removed. I fabricated a temporary hose using power steering hose sections and heat treated elbow sections to make the necessary bends. I am ordering the factory hose section for about $25 to have it ready to go once I replace the rack. One question I have is when I go to remove the original rack, do I have to also lossen and/or remove the steering shaft to undo the universal "rag" joint or is there enough play once the two steering rack bushings and clamps are removed to pull the rack out.
I assume once the old rack has been removed, I can line up the new rack position with the old one within a few teeth so that it can be aligned properly. Is there a trick to that as well? I was just planning on laying them both on the ground and turning the gear on the replacement rack left or right until the inner tie rods line up (the outers could be totally off depending on each car's alignment, who performed the alignemnt, etc.) the inners should be the same form car to car.
Amy info or advise would be great. Just turned 105K on the odo and still going strong.
Happy new year,
Ted
