Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Apr 02, 2004 1:26 pm
When you buy a Japanese take out engine [low miles does not mean low years of service], you end up spending more than the engine costs on rehabilitating things: chain guides, hoses, harnesses , injectors, gasket and seals, plugs, water pump, knock sensors, etc, etc. Resealing both valve covers and replacing front and rear main seals.
We buy engines for $1200 and usually end up replacing around $1300 - $2,000 in external parts and spending a day $800 in labor to get it ready to swap. Then the 25 hours of swap labor.
When you read 40,000 mile take out engines......think of that as in someways a 100,000 mile US engine because at 5,000 miles per year driving and idling all days in between......they can be very very used from years alone.
They have internal and external degreasing machines to make them look good to the untrained eye and spray them liberally with shiny silicone to make the brittle hoses and seals LOOK brand new.
Very few want to spend $5,000-$5,500 on a newish engine since even the 1995 are not worth than now.......in the age and condition where an engine swap would be required.
