Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Thu Apr 03, 2003 1:39 pm
Never heard of a problem like you described about having the switch work with the car off, but who knows... maybe someone has messed with the wiring in the doors (given the light problems in the doors?)
Best bet is to get a good multimeter and your service manual to track everything down. I'd check the center console switches first to see if they're working correctly. Maybe someone spilled a drink in there and cased issues?
With the exact same problem in both doors with several issues, I'd lean toward something with the center switches - I know the windows won't work from the door switches if the center switch cluster is unplugged...
Heath
